Hi guys,
I'm trying to encode with the Ligos plug-in for Premiere and then burn with Nero to SVCD. I'm selecting in both programs the supplied profile/settings for SVCD. My problem is Nero complains the "stream encoding is invalid for (Super)VideoCD". I have tried both CBR and VBR, in both cases with a bitrate around the 2000 kbps. Any ideas what can be wrong?
Note: I tried turning off the standard compliance check and burning the CD anyway but it would indeed not work in my standalone player. By the way, I'm sure this standalone player does play SVCD.
Thanks in advance,
José Carballosa
Hi Guys,
Found a workaround! It seems to be the case that the Plug-in looses the settings when you do it via the menu Project -> Settings Viewer -> Export Settings and then File -> Export Timeline -> Video. It will work OK though if you set it up using Settings button on the Save As dialog that appears in File -> Export Timeline -> Video instead. :oops:
Greetings,
José Carballosa
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 08:44 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 19:55 -
Nero 6, mpeg4 & dvd-plug in
By dll in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2007, 11:05 -
Nero’s DVD-Video/Multichannel Plug-in
By DragonKnight in forum Authoring (DVD)Replies: 11Last Post: 8th Oct 2007, 18:43
