Recently started making this noise when i try to play the origonal diablo. Cant really tell where sound is coming from. Its not very loud unlike the noise a comp made when the power supply went out. Just wondering if anyone has any idea what it is?
HDD bearings make more of a scrape sound. Siren is probably a fan bearing or a cable hitting a fan.
http://www.kiva.org/about -
Then why does it only make that noise when i try to play a game?
Could be the fan on the video card
or could be
the video card is overheating and sending a warning sound.
Stick your nose inside the computer to see if the fan on the video card is spinning. May need cleaning. -
I'll second the overheating alarm idea. when you play a game is when your video card works the hardest = gets hottest.
Modern computers speed up the fan (cpu, case and gpu) when under load and back off for idle.Originally Posted by mac71671Recommends: Kiva.org - Loans that change lives.
It's overheating. Leave the PC plugged into the mains but switch off at the mains socket on the wall (keeps everything earthed). Open up the case and carefully clean out all the dust & fluff from the processor's heatsink, make sure the grills on all the vents in the case aren't clogged up with dust, and make sure that all the fans are spinning smoothly (including the one in the power supply.) If they're not spinning freely then replace with new ones (you can try re-lubricating but it usually only puts off the inevitable for a bit.)
when I had my ati radeon 9800 it was stupid hot and the puny heatsink fan was grossly inadequate. I tore it out and fastened a full size case fan to the heatsink to blast the heat away :P.
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
something similar to Cellulo for MKV?
By DarkPhoenix77 in forum MacReplies: 4Last Post: 27th Jan 2011, 16:37 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 06:39 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
4:3 to Letterbox (or Something Similar)
By christopheramos in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2008, 03:57
