After editing MTS files I render them (Make Movie) into Blu-ray M2TS format(BEST rendering option is ON). Rendering errors progressively getting worse with increase of resolution of MTS files.
Worst outcome comes after MTS files with 1920x1080 resolution:vertical lines appear jagged,numerous horizontal shifts or ripples. Resolution 1920x1080 in M2TS format is critical for my projects. I can't find out what the problem is. Any help?
Dell E520
4Gb memory
CPU:Intel Core 2 Duo E4300 at 1.8 GHz
GPU:Asus EAH4670 HDMI 512Mb
Vista 32-bit SP1
	can you post a source sample and an output sample at a file hosting site? under 50mb each would be helpful.
 but it sounds like an interlacing problem, it may just occur on your computer screen if the media player isn't de-interlacing properly. try something like powerdvd 8 to view it with.
	Commercial Blu-ray videos and original Sony MTS files play by using PowerDVD 9 Ultra on my computer without any errors at all.
 Original Sony MTS Test File:
 http://www.megaupload.com/?d=IXJ1XW2Y
 Same file after rendering by Sony Vegas 9 Platinum to M2TS format:
 http://www.megaupload.com/?d=QDCYI2EQ
 Horizontal line shifts are clearly visible.
 Any suggestions?
 Rendering Conditions.
 Rendering quality:Best
 Video format:AVCHD
 Frame size:1920x1080
 Frame rate:29.97
 Bit rate: 16,000,000 bps
 System Format: M2TS
 Computer:
 Dell E520
 4Gb memory
 Vista 32-bit SP1
  Seeing I Frames with Sony Vegas Platinum?By HoosierGuy in forum EditingReplies: 3Last Post: 17th Mar 2011, 18:32
  SONY Movie Studio Platinum 10 rendering problem!By EagleW in forum EditingReplies: 4Last Post: 4th Nov 2010, 18:52
  Importing an MPEG-4 to sony vegas platinum 9By txpredator in forum Newbie / General discussionsReplies: 0Last Post: 24th Oct 2010, 20:25
  Vegas 9.0 Platinum: Smart RenderingBy Nadious in forum EditingReplies: 7Last Post: 24th Oct 2008, 18:44
  Sony Vegas 8 Platinum... slow renderingBy holyvideoly in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 18th Jul 2008, 21:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
