I've used tsMuxer and mkvmerge to create an mkv from a Blu-Ray disc.
I've done it all correctly using a guide I found on this site. All goes according to
plan until I play it, it plays fine from the start but the if I move the slider it goes
out of sync and also this happens....
I have no idea what i've done wrong if anything, as you can tell from my profile,
my computer ain't slow and I THINK I have all the correct codecs and programs,
any help would be appreciated because i'm putting Blu-Ray discs on my HDD and
watching them on my LCD which saves buying a Blu-Ray player so I would like this
to work, I know I can use RipBot which I have been doing but it takes anywhere
from 6 hours upwards and this method seems a lot quicker.
I've tried WMP, MPC, ZoomPlayer and VLC and it happens in all of them, starts off fine then goes out of sync and I get the above picture every 4 or 5 seconds. When i've demuxed the tracks and then add them in mkvmerge it comes up with a warning saying it can't detect the frame rate, i've set it to 24/0001 which is what it said when I demuxed it, is this right?
problem playing MKV file on a strong computer
By tomchook in forum Software PlayingReplies: 9Last Post: 25th Mar 2010, 19:53 -
problem playing mkv hd files in my pc
By gotenks_fp in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2010, 16:46 -
problem playing mkv x264 1080p
By ioio in forum Software PlayingReplies: 24Last Post: 10th Oct 2009, 21:33 -
Sound problem while playing mkv files
By shorto in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2009, 05:02 -
Problem playing .mkv (matroska)
By mk2006 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2007, 05:33
