Hi all, I got DX50 (DIVX5/6) HD (720p) file that PS3 (fw 2.60) complain about incompatible format. I though PS3 can play newer DIVX format even before fw2.6. As such, I am looking for a good, free, and fast way to make it layable by PS3. I tried RedKawa PS3 Video 9 and although get the job done it is single threaded and took almost 2 hr to transcode a 1 hr video.
Any multithreaded apps that can keep all of my 4 cores CPU busy? TIA for your help.
Xvid4PSP uses X264 for encoding PS3 MP4's and uses all cores. I probably won't use them to 100% across the board, but is it still an improvement. It has presets for the PS3, and the quality is very good. I haven't had anything created by it not play, or not stream with PS3 Media Server. It also handles and produces m2ts files as well, if that is what you need (and you will if you want multi-channel AC3 as Xvid4PSP still can't put AC3 into an MP4 - one it's few oversights)
Read my blog here.
Thank you all. Very quick with suggestion as usual!
One more thing. So XVID is more acceptable by PS 3 than DIVX? Can we use FourCC changer without actually transcoding it? -
The PS3 will happily play Xvid, Divx, MP4 (H264/AAC), mpeg-1, mpeg-2 etc. It will even play some WMV material if you enable it in the system menu. It can browse and play material directly from an iPod (not DRM protected material).
I encode for the PS3 using H264/AAC in an MP4 container for most things, as I can get better quality in the same file size as Xvid/Divx. I only go Divx/Xvid if I need the files to play on other devices as well.
The name Xvid4PSP is just that, a name. It is capable of encoding to a wide range of formats.Read my blog here.
How to convert any video to MP4 iPod, iPhone, PS3, XboX360 using free tools
By Baldrick in forum User guidesReplies: 74Last Post: 7th Apr 2014, 00:03 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
Video format for PS3
By Jacks_Daddy07 in forum Video ConversionReplies: 2Last Post: 30th Jan 2009, 08:57 -
Looking for a video format for Ipod, Ps3, PSP, 360
By Lucky_Bagota in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2008, 17:19
), but you might also give
