i was converting one old DVD to *.mkv with x264 and AC3 audio with Original FPS being 29.97 to new 23.97.
what are the ill effects with that as i could not find any difference in the above format.
It depends. If the DVD was of a movie then there is a good chance that it was actually 23.976 fps, with pulldown to get 29.970 fps playback. In that case, conversion to 23.976 fps MKV file will be fine.
If, on the otherhand, if the DVD has come from a video source, or has been hard telecined to 29.970 fps, you will get audio sync issues encoding at 23.976 fpsRead my blog here.
Unless the conversion software throws away one of every 5 frames. In which case you'll get jerky video.Originally Posted by guns1inger
How to change 30 fps to 29.97 fps ?
By pchan in forum Video ConversionReplies: 5Last Post: 9th Feb 2012, 19:57 -
tsremux ? Multiple m2ts diff fps..join result =delay
By newbtube in forum Video ConversionReplies: 2Last Post: 29th Mar 2011, 16:12 -
How to change MKV from 50 fps to 25 fps skipping every second frame?
By andreyyshore in forum EditingReplies: 11Last Post: 5th Feb 2011, 15:09 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Change FPS
By maza1967 in forum Video Streaming DownloadingReplies: 8Last Post: 9th Mar 2010, 19:52
