I'm trying to join together 22 mp4 files and burn them into DVD format using DVD flick. I was told in another forum that I could do this by putting all the files under one title, but that there would be a stop between each file if I used the default mode. How do I get it to play as one continuous movie. I am not concerned with menus or anything like that, I just want the movie to play. Also is the mp4 format for portable devices supported with DVD flick?
You can also see if they will merge. Add the first one-> Edit title-> Video sources, then add the rest there.
Newbie question: What format is used in those *.mp4 files? DVD wanted
By TJA in forum Video ConversionReplies: 11Last Post: 21st Jun 2010, 13:54 -
Burning 1000's of files to multiple dvd's
By lordhutt in forum ComputerReplies: 12Last Post: 14th Dec 2008, 15:45 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 13:01 -
MP4 files in MOV format - how to play in dvd/divx player
By glen_s in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 03:49 -
can i play mp4 format files on my dvd player
By vampelle in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2007, 05:36
