I have problem with DVD, that menu doesn't show. When I open the DVD, it jumps directly on film. But if I chose menu button during the film, it jumps to menu normaly. Any solution?
Thank you for your help.
Did you author this yourself ? If so you need to set the menu as the first play item so that the player knows what to do.
If you did not author this yourself you will have to rip the disc to your HDD, then use PGCEdit to change the first play behavior as per this guide : http://jean.laroche.free.fr/Jumping0.4.3.1/index.htmlRead my blog here.
MY LG BD-ROM/DVD doesn't show under My Computer
By dude905 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 21st Dec 2012, 07:20 -
subtitle doesn't show in MPCHC
By alexanderex in forum SubtitleReplies: 2Last Post: 28th Feb 2011, 20:45 -
DVD recorder doesn't show colours
By mireille in forum Newbie / General discussionsReplies: 8Last Post: 2nd Nov 2010, 06:08 -
Burn AVI + SRT, but doesn't show up on TV
By waro in forum SubtitleReplies: 3Last Post: 19th May 2009, 10:21 -
Video TS folder doesn't show up after DL.
By crowheart in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2007, 10:56
