I am a newbie at all this.
Recently built a computr to use for storing videos I download , TV shows, Music, photos ECT.
I have it hooked to my 53 Inch Projection HDTV, a older model with a DVI port.
I conenct it to a video card with a DVI connection. and use the Beyond Media software and firefly remote that came with it.
I like it but the Beyond Media software is very buggy.
I am running windows XP Home, and have random errors, saying the program is non responsive, or an error has occured and needs to shut it down and asks me to send the info to Microsoft, ect. Even though the program was working fine, some glitch happened. This happens every so often.
I downloaded XBMC, which works smooth, but the remote doesnt work other then up and down and select.. The play/start/ect buttons dont work. I looked on Firefly's website and since they dont support this software anymore, not much help.
Im looking for somthing not too expensive, under $50.00 if I can. I don't have a lot of cash to spend on somthing new.
Mainly just want to be able to put together all the shows I download to use the remote to open up the folders and play from there, rather then getting up every time to start it from the computer.
Thanks!
If you haven't found it already, all of the HTPC software is listed here: https://www.videohelp.com/tools/sections/htpc
There is also a HTPC specific forum where you may get a better response.
For the short while that I had a HTPC setup, I was running XP MCE.Google is your Friend
Media Center + Multiple TV's + Touchscreen Remote
By jc0r in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2012, 22:07 -
any good "my movies" plugins for Windows media Center?
By craig198 in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Jan 2011, 14:47 -
Need help finding a good media center.
By ReaperBoy2010 in forum Media Center PC / MediaCentersReplies: 4Last Post: 6th Oct 2010, 08:59 -
Which remote control with IR blaster to use with Windows 7 Media Center?
By usually_quiet in forum Media Center PC / MediaCentersReplies: 5Last Post: 1st Sep 2010, 19:59 -
vista media center remote
By skierrob in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 03:33
