  1. Hi
    I have the following problem. I want to make a DVD. I have the 3 VOB files that contain the stuff I want to be in the dvd. However I need to cut out 5 min in the start of the first VOB and after that I want to create a dvd of the three VOB files.
    How do I go about?
    Easiest using an all-in-one solution like TMPGenc Authoring WOrks or Nero vision.
    Or if you want a free solution, try cut the vob using mpg2cut2. Then author/make the dvd from the vobs/mpgs using gui for dvd author or dvdstyler.
