I demuxed a vob file and got a m2v, and two ac3 files. then I used Imagomuxer and muxman to remux these files. Basically I wanted to change the order of the two ac3 files. both imagomuxer and muxman couldn't accept the ac3 files. can s.o. know why and help? thankyou
	Yeah, how did you demux? If the AC3 is in a VOB file, it's compliant and Muxman should accept it when remuxed. Use DGIndex maybe and File->Create Project and Demux Video. That'll also give you the M2V and 2 audio files.
 Better might be to change the order in the original DVD (if this is a DVD you're starting with) using PGCEdit, rather than doing it how you are. Here's a guide:
 http://forum.digital-digest.com/showpost.php?p=296707&postcount=1
  Help me automating demux-remux dual audio files...By CactusMan in forum Newbie / General discussionsReplies: 8Last Post: 6th Jan 2012, 21:59
  Audio/video out of sync after demux-remuxBy CarryNL in forum SubtitleReplies: 0Last Post: 14th Sep 2011, 15:31
  Capture out of sync after demux/remux (framedropping)By Bingo-days in forum Capturing and VCRReplies: 3Last Post: 13th Jan 2010, 09:41
  demux m2ts streams and remux them together with srt subtitlesBy TwilightMatt in forum Video ConversionReplies: 5Last Post: 9th Dec 2009, 12:10
  Demux mkv -> remux DivxBy nsx3000 in forum Video ConversionReplies: 4Last Post: 15th Sep 2009, 10:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
