If I have ffdshow installed do I need to remove any pre-existing codecs? I was reading something about the K-lite codecs and how it was important to remove any pre-existing codecs because it could cause damage to the computer. I don't know if that's true or even what that's supposed to mean. Can anyone clear up this confusion for me? Thanks.
Simple answer is not to use codec packs at all. K-lite etc ate all asking for trouble.
FFDShow is not a codec pack in the same way that k-lite is. K-lite and the like a collection of many different codecs, complete with has-arsed installers, often conflicting settings, and a tendency to be unable to be removed cleanly after the fact.
The first and best option is to install only the codecs you really need for converting, and to use a self-contained player, such as VLC or The KM Player, that don't require many external codecs. If you do need something broader then use FFDShow.
But don't put k-lite and it's ilk on your system if you value it in any way.Read my blog here.
Whatever codec you had been using for AC3 playback wasn't doing a very good job. You chose a different codec through FFDShow to decode it, and you problem was fixed. Part of the problem with codec packs is that you often get conflicting settings and codecs that interfere with each other. You then get unstable or unpredictable playback, and can waste long hours tryong to resolve the issue.
Read my blog here.
Putting a codec pack on your computer is about on par with sticking your pecker in a blender. What happens afterward ain't pretty.
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 10:44 -
Having issues with dvd ripping and codecs - cant tell whats installed
By alex.ap.pacman in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2011, 01:40 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Windows 7 how to list installed codecs
By felix in forum Newbie / General discussionsReplies: 2Last Post: 21st Dec 2009, 08:33 -
Application to View Codecs that are Installed on Your System
By JBredensteiner in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 01:58
