I was wondering if any of the Video Help Gods had any suggestions on some software I could try.
I'm looking to split recorded (legal) internet and satellite radio dumps that are currently in MP3 format at the pause-breaks. Similar to the way audio tape players can skip "tracks" by listening for gaps. Streams range from around an hour to 8 hours plus. I want to split them to single tracks per song.
Suggestions?
mp3DirectCut has a pause detector. Also, Audacity has a silence finder.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Use mp3DirectCut if at all possible. It cuts MP3s losslessly.
Other editors have to decode and reencode.
As well as its pause detection (on "Special" menu) you can just look at the waveform and do it visually.
Note that it can only have one file open at a time; but you can open several copies of the program, and cut and paste file segments between them. -
Thank you; I'll give it a try. I don't care much for editing, just something that I can set to go and walk away from and let it do it on it's own. As long as the resulting MP3s are in the majority of being close to accurate in silence detection, I don't care much beyond that. Just trying to put together an MP3-CD to play later.
picture breaks up on AVCHD from MKV files
By daj38 in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Sep 2010, 11:19 -
Creating M4B files from MP3, then splitting
By hungledink in forum AudioReplies: 1Last Post: 12th May 2009, 16:54 -
recommendations for MP3 format for long lectures
By tomchook in forum AudioReplies: 6Last Post: 24th Feb 2008, 14:00 -
Cutting/Splitting an MP3 Audio with MP3Direct Cut
By UmmAddan in forum AudioReplies: 2Last Post: 22nd Jan 2008, 19:03 -
Suggestions for splitting MP3 into 10min chunks?
By j_hallgren in forum AudioReplies: 3Last Post: 7th Jan 2008, 22:36
