I can't seem to find anything referring to my problem.
I have a MKV file that has subtitles. Using ConvertXtoDVD I am able to successfully convert the file, no problems with subtitles. My problem is, by default, subtitles are enabled. I'm guessing I can't see the forest through the trees, but is there a way to disable this defualt behavior within ConvertXtoDVD?
I would like to keep the subtitles on the DVD, I just don't want to have to turn them off everytime I watch the movie.
Or, is my only option something like IFOEdit?
Thanks for the help...
I've never seen that happen. I usually have to go to DVD Shrink or Recode to get them to come up automatically.
They have always always been off by default for me. No specific setting to make them on or off by default in ConvertXtoDVD 3.5. You can always use PGCEdit to switch the default behavior if necessary.
Read my blog here.
Thanks, never thought of DVDShrink, usually only use it when I need to shrink.
The subs are ON by default in the MKV, maybe that's why they are on in the resulting DVD. Will check out PCGEdit as well. I accomplished it in IFOEdit last night, but figured there should be a way in ConvertXtoDVD as well.
Disabling auto-play
By videohalp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jan 2012, 10:28 -
Help with Disabling Subs by Default
By TheAlmighty in forum SubtitleReplies: 6Last Post: 16th Dec 2009, 04:52 -
A minor problem using CovertXtoDVD ( double layer dvd+r needed)
By nadizo in forum Newbie / General discussionsReplies: 11Last Post: 18th Mar 2008, 17:13 -
overscan - CovertXToDVD doesn't like my Avisynth scripts
By spicediver10191 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2008, 16:40 -
Question about coverting to dvd using CovertXtoDVD...
By nadizo in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2007, 05:54
