I play my movies on my dvd player with usb in it. But, alas, "same name trick" (like ex. movie.avi and movie.srt) doesnt work. But yesterday, I was able to watch a movie (single AVI file) which included a subtitle that can be turned on/off, I believe it's called "softcoded"(?)....How do I "re-convert" my AVI to AVI (too) with softcoded subtitle in it? thanks in advance!
Probably better asked and answered in our Subtitle Forum. Moving you. And you might check the 'stickies' at the top of that forum.
And welcome to our forums. -
@red: im so sorry, haven't noticed the subtitle section...again, my apologies...and thanks for welcoming me
@Midzuki: its only one of those "clone" which is china made
'just to clarify...the DVD disc works A-fine with subtitles....it's only the movie when played via its USB port that i'm having problem with
thank you
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55
