I want to capture a frame from my home video off of *.mts file while playing on PowerDVD.
I've try unlead video to capture the same frame, but the software degrate the quality of the picture.
it's 1920x1080 format.
is there a better software preserve the quality of the picture or some way to capture it out of PowerDVD?
I don't have the latest PowerDVD but VLC will do it in high quality with choice of deinterlace method. On the menu bar go to Video_Still_Snapshot. You can use any deinterlace mode in that same menu. Here is a quarter res 960x540 sample snapshot from 1080i broadcast.
Click on picture to see 960x540 res
http://www.kiva.org/about -
Try media player classic, file save->image. You probably need to install ffdshow.
Or VLC Media Player should probably work fine too. -
Does anyone know of any software out there I can purchase to frame grab multiple images from HD video .mts format that gives a high resolution still image shots?
Thanks -
Pretty sure PowerDVD has a snapshot facility. I know mine has (version 7.3).
I capture 1920x1088 shots from my bluray backups regularly.
Capture as BMP for lossless, quality images.
It stores them here: C:\Program Files\Cyberlink\PowerDVD\Snapshot as default.Last edited by transporterfan; 14th Jan 2012 at 07:23.
video frame rate column in Windows Explorer (XP Home Edition)
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2011, 11:38 -
Home Video Capture
By Jac26 in forum MacReplies: 7Last Post: 2nd Jul 2009, 22:20 -
1080i video capture - is there any cards at a reasonable price
By mikesbytes in forum Capturing and VCRReplies: 7Last Post: 1st Feb 2008, 14:53 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 16:25 -
dazzle video capture frame skipping
By VistaXP in forum Capturing and VCRReplies: 2Last Post: 2nd Jun 2007, 18:00
