what i am trying to do is encode vob to x264...
I have a few ripped (using cloneDvD) vob files ....
some have encoded without any error log.......and few r not encoding at all ....(using the same resolution / x264 profile on all )
error log says: An error occured x264 [error]: could not open ..........filename.avs
what does it mean???
I created the d2v files.......created the avisynth file.......choose the x264 profile and bitrate....que....then start ...then error?????
why????
the thing i noticed is that ...megui and mpc says the vob has resolution 720*480......but the windows media player plays it at 640*480....which i believe is the correct one................but i have encoded few similar vobs in similar way ...but few r giving error message............
can any one help me plz..thank you
1) post your avs script
2) can you preview that avs script in mpc or virtualdub, what error message does it give
3) post the megui log file -
avs file attached.........
sorry but how do i load avs file in mpc............when i go through openwith option ... avs file in mpc it says cannot render....
vts_01_1.avs -
If you can't preview/render the avs script in MPC, it won't work in megui or any application. It means there is a problem with your script
Try re-indexing (i.e. create a new .d2v file) and create a new avs script. If you move the files, or update to a new version it needs to be re-indexed. If that doesn't work, do it with DGIndex manually to create the script (not using megui d2v creator)
How To Convert Any .vob/.avi/.divx video To x264 In Megui
By jamespoo in forum User guidesReplies: 4Last Post: 13th Jun 2011, 22:31 -
MeGui: error in encoding: "x264.exe:unrecognized option --progress"
By Julllie in forum Video ConversionReplies: 4Last Post: 30th Apr 2011, 06:21 -
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 22:43 -
x264.exe error in Megui during encode
By glassbottomboat in forum Video ConversionReplies: 0Last Post: 6th Dec 2009, 23:55 -
An error x264.exe in MeGUI program
By mahogany in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2009, 14:27
