I am using ConvertXtoDVD to convert an MKV to DVD. All my settings are good in ConvertX, the encoding works good, but all my subtitles are cut about halfway off and sometimes they run off the screen. I have tried multiple settings for the video resize method. I have used automatic for the best crop and I have tried letter box and they all seem to do the same thing. I am assuming that this is an issue with MKV files because this has happened to multiple files. Help would be a appreciated. Thank you.
Hi there.
Though I have never used ConvertXto DVD, I guess the MKV file
has SSA subtitles designed to work in Hi-Def resolution (greater than D1),
and the application is not modifying the SSA header and the Style
font-size accordingly. -
I think you are exactly right. The files were Hi Def. Can I assume that there is no way around this?
You should extract the SSA subtitle from the MKV file with
MKVtoolnix or AVI-Mux GUI, then edit the subtitles with [s:baace227ad]Aegisub[/s:baace227ad] SubStation Alpha.
[EDIT]
P.S.: You might as well use Wordpad, Notepad, EmEditor, etc.,
if you take the time to learn the SSA specifications
( http://au.geocities.com/rashojin_mizuki/Main_One/ssa-specs.pdf )
I have just checked, the latest version of Aegisub is 24MB big
WTF
Help with avi/mkv conversion to vob with enabled italic subtitles
By hibbs in forum Newbie / General discussionsReplies: 0Last Post: 2nd Oct 2011, 22:18 -
MKV conversion with subtitles
By losernoob in forum Video ConversionReplies: 0Last Post: 16th Oct 2010, 23:20 -
Need Help on XviD4PSP (Conversion of MKV to AVI, subtitles SPU codec)
By gallen16 in forum Video ConversionReplies: 3Last Post: 10th Oct 2010, 11:44 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Conversion of MKV subtitles to DVD
By BillinToronto in forum Video ConversionReplies: 3Last Post: 24th Jul 2008, 09:36
