Hi all, I need to capture some VHS footage, I just cant decide what device i should get, I want the captured footage to be equal in quality to the oringal VHS tape, which is quite good.
The cheapest way would be to get one of these
And a scart converter.
But I'm really not sure how well this would capture the source from a quality point of view, has anyone tried one of these ?
The video footage i want to put onto DVD is only 30 minutes so I can use a high bitrate transfer.
The other option is to get a TV card, not sure what one to get & what leads I'd need though, also my OS is windows XP home sp2 & I've seen some TV cards that say for windows media centre.
Also what software would you reccomend, preferably free.
I really need some advice on this, I'm desperate to buy one of the above but dont want to get the 'wrong one '
Thanks in advance.
* still trying to work it out *
Dal... -
How much vhs footage?
DVD Recorder is easiest, computer capture takes alot of trial and error.
This is the top topic on this forum, search the archive.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Look in restoration form for info on VCRs, TBCs, etc too -- it requires more than a capture device to make a good DVD.
Use Canopus ADVC55 to transfer the video from VCR to your computer. It will give you the best results. You can edit the DV file before convert to DVD.
Slightly OT: Roxio announces VHS capture Device Solution
By terryj in forum MacReplies: 5Last Post: 1st May 2012, 00:19 -
Best VHS capture device
By underworldmagic in forum Capturing and VCRReplies: 27Last Post: 2nd Jan 2012, 06:09 -
Need advice: VHS capturing device
By nikgelfi in forum Capturing and VCRReplies: 28Last Post: 2nd Apr 2011, 17:25 -
Best outboard consumer capture device today? VHS, LD, camcorder and HD DVR
By cosmichippo in forum Capturing and VCRReplies: 4Last Post: 11th May 2010, 14:46 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
