Results 1 to 22 of 22
    Jun 2006
    Keep getting this error when loading DVD source or vob subsets
    VOB2MPEG-DVD Player
    Could not get interfaces, attemped to read or write protected memory
    this is often an indication that other memory is corrupted
    Thanks,
    Apr 2004
    Miskatonic U
    Vob2MPG requires .net 2 (it says so, right on the pack). I suspect that you do not have this installed on your computer.
    You may not be able to install it if you are running XP Service Pack 1.
    From the Vob2MPG website :
    (requires .Net Framework 2.0 and XP SP2 or greater)
    There is no sane reason not to upgrade to Service Pack 2 if you are running XP.
    You can get .net 2 here : http://www.microsoft.com/downloads/details.aspx?familyid=0856eacb-4362-4b0d-8edd-aab15...displaylang=en
    Read my blog here.
    Jun 2006
    all is installed
    Apr 2004
    Miskatonic U
    Your specs say you have SP1 in your profile.
    Are you sure you have .net 2 installed ? .net 3 does not include .net 2. They are separate installs.
    Read my blog here.
    Jun 2006
    have not updated specs, all is installed both .net2 and three the installer for vob2mpeg 3 installed .net3, programs runs,
    but will not preview, gives error.
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What build?
    Can you play DVDs on your PC with other applications? WMP for example?
    Jun 2006
    3.0.021 and yes
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    3.0.021 doesn't install .net 3 (3.0.0020 did however)...
    What directX version do you have?
    Jun 2006
    9.0c
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    CAn you ignore the errors and extrate a small title and send me the log please?
    Jun 2006
    what log and where?
  12. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    From here:
    Jun 2006
    ************************ SYSTEM INFORMATION ************************
    ***************************** VOB2MPG *****************************
    Title:
    Version: 3.0.0021
    Executable: C:\Program Files\BadgerIT\VOB2MPG v3\%APPNAME%.EXE
    Executable size: 771 KB
    Executable size in bytes: 789504
    Executable CreationTime: 1/1/2000 12:00:00 AM
    Executable LastWriteTime: 1/1/2000 12:00:00 AM
    Executable LastAccessTime: 1/1/2000 12:00:00 AM
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 21.6 GB
    DeviceID: D:
    FileSystem: NTFS
    FreeSpace: 355 GB
    DeviceID: E:
    FileSystem: FAT32
    FreeSpace: 998 MB
    ********************* END OF SYSTEM INFORMATION ********************
    /v="F:\VIDEO_TS" /t=1 /o="C:\vob2mpg\Title_1.mpg"
    16:58:31
    Extracting from Title: 1
    16:58:31 vPaths: F:\VIDEO_TS\VTS_01_1.VOB,F:\VIDEO_TS\VTS_01_2.VOB, F:\VIDEO_TS\VTS_01_3.VOB,F:\VIDEO_TS\VTS_01_4.VOB, F:\VIDEO_TS\VTS_01_5.VOB,
    16:58:31
    16:58:31 =============== Virtual File Details ===============
    16:58:31
    16:58:31 VTS_01_1.VOB : Length = 1073709056 (0.99 GB) : vPosition = 1073709056 (0.99 GB)
    16:58:31 VTS_01_2.VOB : Length = 1073709056 (0.99 GB) : vPosition = 2147418112 (1.99 GB)
    16:58:31 VTS_01_3.VOB : Length = 1073709056 (0.99 GB) : vPosition = 3221127168 (2.99 GB)
    16:58:31 VTS_01_4.VOB : Length = 1073709056 (0.99 GB) : vPosition = 4294836224 (3.99 GB)
    16:58:31 VTS_01_5.VOB : Length = 103151616 (98.3 MB) : vPosition = 4397987840 (4.09 GB)
    16:58:31
    16:58:31
    16:58:31 Extracting chapter: 1...
    16:58:31 Start position: 0 End position: 313229312
    Jun 2006
    any help with this yet?
    thanks,
  15. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Not yet. I am looking at rewritting the dvd player but will take a day or two. If you "ignore" the error are you able to extract?
    Jun 2006
    yes I'm able to extract, and thanks for the help
    Jun 2006
    have paid for the pro version and downloaded it, but no serial# as of yet.
    thanks again
  18. Member
    Jun 2006
    downloaded new version cannot get preview to work
    thanks
  19. swbisbee is the .net framework up to date on your computer? your specs say you are running sp1 so you might go to m.s. and see if there are any updates at least for .net.
    it does work on xp, i was just using it with the preview.
  20. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Also what Mpeg Decoder do you have?
    Jun 2006
    have not changed my spec as of yet, but yes am running the right .net frame work if i was' t the program would not work and what mpeg decoder should i be using
    thanks
  22. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well by default XP can't play DVDs.... so there needs to be a mpeg2 decoder which can enable you to do so. If you have a DVD player (software) like WinDVD or PowerDVD, for example then you will have their decoder... What do you use to play DVDs normally?
    Personally i have DScaler Mpeg Filters installed as my decoder - free and very good. Perhaps the first thing to do is to install that and reboot and lets see where we are. If that fails we can try some other things.... one way or another we will get you up and running with the preview.
