  1. I followed the instructions here http://www.geocities.com/jbboi4/hjsplit.html
    But even after I renamed my avi files and add extensions .001 , .002, and .003 , it did not work
    Files
    Movie.avi.001
    Movie.avi.002
    Movie.avi.003
    The combined file is only part 1. Am I doing something wrong?
  2. If your original files weren't split using HJ split in the first place, it won't work.
    What are you trying to do? If they were playable avi segments, you can join them with virtualdub or avidemux.
  3. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Try using virtualdub to join your avi files.
    http://www.dvd-guides.com/content/view/14/59/
    Donadagohvi (Cherokee for "Until we meet again")
    Jan 2003
    India
    hjsplit splits the binary file. It adds extensions automatically.
    It can join split binary files split by it or by anything else which follows the same rule for naming the split files.
    You are doing something totally wrong. Unless you tell us from the beginning what you are trying to do, it is diffficult to help you.
    canada
    If they are regular avi files to begin with do as poisondeathray suggested.Remember to save as direct copy for video if using virtualdub.
