There are some skips on a DVD-VIDEO, could DVDFab correct these errors when ripping the disc? Thanks.
Yes/No/Maybe
Vague questions get you vague answers. Bottom line is - it depends.
What is causing the skips ? Is it bad media, bad burning, bad authoring, bad source ?
DVDFab simply extracts data from the disc. It doesn't change the data or perform miracles. If the data is missing, too damaged, or was never there to begin with, then DVDFab may be able to do nothing.
If it is a damaged disc, there may be better alternatives - ISOPuzzle is pretty tenacious when it comes to retrieving data from damaged discs, although it can't do protected discs unless you have AnyDVD running in the background.Read my blog here.
DVD Burning on PC - Skips in Playback
By opieandy in forum Authoring (DVD)Replies: 23Last Post: 23rd Jun 2011, 16:35 -
recommend dvd player skips fbi warning
By joshua4 in forum Software PlayingReplies: 5Last Post: 24th Jun 2010, 01:43 -
DVD Flick causes skips/lags when switching chapters
By takearushfan in forum Authoring (DVD)Replies: 1Last Post: 20th Nov 2009, 22:31 -
Burned DVD skips in standalone player
By lj01 in forum Newbie / General discussionsReplies: 14Last Post: 21st May 2008, 10:07 -
DVD skips like crazy.
By tmac2085 in forum Newbie / General discussionsReplies: 31Last Post: 13th Sep 2007, 06:55
