Hi everyone. I say "maybe" in the title because I can actually play any file if I open the player, go to file, browse for it, and then open it that way. But if I just click on the icon (which all worked fine until yesterday), I get this error. Media plays fine on Real or Windows Media Player, but some of the files I have don't work on those, hence MPC. I've tried downloading about every version of MPC I've seen, and nothing works. Ad-Aware and AVG turn up no problems. And I haven't changed or updated anything lately. I even tried changing them all to run on media player and deleting every last vestige of MPC, then redownloading and installing it and trying again, and I get the same error.
I'm not sure what that means. If it means change the default program for each file to something else and then change it back, I tried that. However, to do that for all extensions period, I'm not sure how. I just did everyone I actually have.
I've been having that problem myself lately. The solution (and the problem) for me was to hit ctrl-alt-del to open the task manager. Seems that a failed load will leave a zombie process called mplayerc.exe running. Click on that process and choose End Process and mpc should work again. I only have this problem in the newer CCCP (haven't tried other codec packs). I keep a copy of "Combined-Community-Codec-Pack-2008-01-24" around because it doesn't have home-cinema in it. Personally I don't see what's so great about home-cinema, but that's because I haven't run into anything the old mpc can't handle. Hope that helps.Originally Posted by BWMagus
Edit: This is for Windows XP - don't know if Vista is the same - don't have it, don't want it
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
RipBot264 error in MPC crashes re-encode
By gonzalu in forum Blu-ray RippingReplies: 3Last Post: 6th Apr 2009, 15:52 -
Error Comment on GOM AND MPC Video player with MKV
By cutefix in forum Software PlayingReplies: 21Last Post: 1st Apr 2009, 23:30 -
MPC Home Cinema - How to Resume Play at the Same Point?
By blizno in forum Software PlayingReplies: 1Last Post: 13th Mar 2009, 16:03 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22
