I have sonic dvd burner software on my pc that came with it. When I try to burn a movie to dvd, it says it cannot make a thumbnail because there is no decoder installed. I have burnt movies on this software before with no problems. Am I doing something wrong?
PLEASE ELABORATE
What is the source file? Is it already DVD compatible? Are you converting to DVD format? Is your software trying to convert to DVD format? Exactly at what step you get the error message?
Also I advise - go through the fantastic "guides" & "How to" already posted on this forum by some really amazing people ! -
I'm a bit confused also. What does a thumbnail have to do with DVD burning?
If you mean a MPEG thumbnail on a folder, then it sounds like your MPEG decoder has a problem. Or is this a Windows Explorer error? Then it may be a file association problem.
And welcome to our forums.
I also am trying to use Roxio (Sonic) MyDVD to burn a Video DVD. It may not be the best program but it's been OK so far. At least the DVD's burned with it play on all of my players. However when I use the Add Files function in MyDVD to import a previously saved .avi file (Xvid I believe) I also get the error message "Could not make a thumbnail. Make sure you have the appropriate decoder installed. -47010". I could get a better authoring program but I'd prefer not to. Hopefully this is enough information. How do I obtain the appropriate decoder and how do I install it? By the way, a workaround is to use Windows Movie Maker to import the file(s) > Save to My Computer > Other Settings > High Quality Video which creates a .wmv file that can then be imported into MyVideo however this seems to require converting the file twice, which takes a LONG time.
Go the Tools section. Go the the area called Codecs. Find Xvid on the list and follow the links. Install the Xvid codec. If MyDVD still refuses to work then get something better.
Read my blog here.
This worked. I have no idea if both steps are required, or why it worked, but it did. First: Open Windows Explorer, go to folder containing your .avi files. Set view to thumbnails. Second: Start > Programs >> DivX Codec > Decoder Configuration Utility > Tab Decoder > Uncheck "Use advanced hardware overlay". My bet is that the second step was the relevant one.
AVCHD Thumbnail
By yardline in forum Authoring (Blu-ray)Replies: 1Last Post: 20th May 2011, 08:51 -
tp thumbnail
By TicTatToe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 14:05 -
Animated thumbnail (playing thumbnail) in DVD menu??
By blizzery in forum Authoring (DVD)Replies: 13Last Post: 9th Nov 2007, 02:46 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
burn 3 or 4 divx movies with autoplay menu, thumbnail?
By bob58user in forum Newbie / General discussionsReplies: 8Last Post: 19th Jun 2007, 19:37
