Hello, i have this player - pentagram eon slide-r it is based on Chipset: Rockchip 2706 + Wolfson 8750BG
AMOLED 2,8 QVGA 320 x 240 , 262t colors
Max resolution for video files it can play is : 624x 352
But I have that video (it is free, elearnig about flex from adobe site) http://ifile.it/aric58x
and it is 1024/768
How to convert it to that player ?
when i convert for max res i cant see code, details, it is useless...how to convert to see everything, every letter and learn ?
thanks..
The maximum resolution for files it can play may well be 624 x 352, which is too low to get clear images of screen shots on, but the display of the unit is far lower than that at 320 x 240, so you really don't stand a chance. That type of screen is designed for watching youtube and music videos, the occasional movie where fine details don't matter, and for reading the menus of the unit itself.
Basically it is completely the wrong unit for what you want to do.Read my blog here.
OK thank You...
is there any portable player which can display that ? or wich have some zoom option to allow me to zoom part of screen i want to see more detailed ? -
Most portable players only have the grunt to play material up to 640 x nnn or less. What would probably suit you better would be a net book, like an eee PC or an MSI Wind. 8" or 10" screen with up to 1200 x 800 resolution. They don't have the grunt to play HD videos, but SD, and something like screen caps encoded with Techsmith should play OK.
Read my blog here.
and i found that - ainol v6000hdb http://www.itechnews.net/tag/ainol-v6000hdb/ what about it ?
It's screen is also very small. It does support 720p, but there is not enough information there to know if you can scan around the display or if it just squeezes it into fit. I suspect the latter. The only saving grace for this device is that you can output 720p to a larger screen TV if you have one. But that is hardly a portable solution.
Read my blog here.
High Res Time Lapse images to AVCHD video (play on Viera TV via SDHC)
By Deefa in forum Video ConversionReplies: 5Last Post: 16th Jun 2010, 05:21 -
Looking For High Res Animation Advice
By David Bethel in forum Newbie / General discussionsReplies: 119Last Post: 8th Mar 2010, 12:09 -
Converting High res JPG File into HD Slide show/HD Movie
By dominic01 in forum Video ConversionReplies: 4Last Post: 13th Oct 2009, 02:58 -
Advice on High Res Video Capture Hardware
By Gregus in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 15:54 -
High Res Presentation video (Frapsed)
By Flawe in forum Video ConversionReplies: 1Last Post: 28th May 2007, 07:01
