I record streaming audio (using TotalRecorder) and when I cut it up using MP3DirectCut the tags can't be read by my car MP3 players. I believe it only happens with VBR recordings. Is there a work around or fix? Perhaps something to rewrite the VBR headers? FWIW WinAmp reads and edits the tags just fine, although the rewritten tags aren't recognized in the cars either.
	there are at least 3 different types of mp3 tags(id3v1, id3v2, id3v3...). different editors write different types. try some others.
	MP3DirectCut has a setting to "Keep ID3v2 tags on normal save". If that's set it will just copy the original tags.
 It can also write ID3v1 tags.
 See Menu: Edit/Tag ID3.
 Otherwise, there are plenty of dedicated tag editors.
 I like EagsOn, freeware. Can edit batches of files together (eg, albums), either v1 or v2 format or both.
 http://www.snapfiles.com/get/eagson.html
	You guys missed the point. The file(s) play and display the tags fine until I use MP3 DirectCut. WinAmp reads them fine. I believe DirectCut screws up the headers and WinAmp is more forgiving. I need som way to correct this.
	So use a tag editor, as I mentioned. With EagsOn select a folder and make a trivial addition to all the file tags (eg, to the "Comment" field), it should rewrite them all.Originally Posted by olyteddy
 But MP3DirectCut is the best option for editing MP3 otherwise, as it does not reencode the audio.
  My MP3 ID3 Tags are being changed?By Denvers Dawgs in forum ComputerReplies: 2Last Post: 31st Mar 2011, 18:08
  Edit XMP-tags in MP3By Fredrik_A in forum AudioReplies: 0Last Post: 4th Nov 2010, 08:54
  flac to mp3 preserving tagsBy AlanHK in forum AudioReplies: 5Last Post: 29th Jul 2010, 23:35
  what is the equivalent of ID3 tags for avi or videoBy carlos28355 in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2009, 23:30
  Mp3 tags for Zune problemBy ultraman36 in forum AudioReplies: 1Last Post: 14th Mar 2009, 16:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
