Hi,
Is it possible to detect a precise frame with a scene detector tool like ComSkip.
In a video I recorded, I got some errors from my decoder ("weak signal") so it display a small red dot in the bottom right of the screen.
It's a pain to look at whole video frame by frame. So it is possible to detect that point and mak the beggining frame of each siganl cut ?
I saw that comskip use tv channel logo but it it possible to tell it a special area where to look for a special logo/shape ?
If you can make a logo.txt (logo mask) file that specifies where and in what directions the pixel transitions should be looked for then comskip will process and calculate for every frame the match with the logo mask.
Use a regular recording with logo to have comskip learn and generate the logo.txt file and then edit the file so it can be used to recognize the red dot -
I try on a video with a logo but there is no logo.txt file generated. Do you know who can I generate one ?????
I do some other test, when the logo is bugger it is found, but the logo mask is not easy to edit.
Here is a sample image when there is a signal lost:
The position/range of detection is easy to edit the how to build the logo mask ????
I do a sample video with a red rectangle to simulate a logo (I put the following values, width=48pixels, height=24pixels, left=620 pixels, top=36pixels)
After analysis, I got the following mask:
So, how can I edit it to scan for the red dot in my sample image ?
Subtitles in video : detect time position
By Urban20 in forum SubtitleReplies: 2Last Post: 15th Nov 2011, 03:24 -
Using video presence detector to detect blank video signal from switcher.
By rabbi in forum Newbie / General discussionsReplies: 0Last Post: 6th Jul 2010, 01:30 -
Old Studio 8 won't detect scenes or audio
By BwanaP in forum EditingReplies: 3Last Post: 1st May 2009, 09:17 -
How to detect errors on Video files
By barry_w2 in forum Newbie / General discussionsReplies: 2Last Post: 9th May 2008, 21:58 -
Video skips scenes
By joelson in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2008, 08:07
