This just started happening and I may know what it has to do with. I recently had to update the Divx codec to the latest version. It seems that after that update this problem started. Whats strange is now I get an almost right on 4gig VOB set. Usualy it is 4.35gig. The original AVI has everything but the last few minutes get cut out when S2D makes the MPG thus creating an incomplete VOB set. So far I have just reinstalled S2D to its newest version but the problem is still there. I have tried 3 different files and they all do it. I have not tried a non Divx file yet.
As I try to find a work arround to the issue can you view this log file to see if it gives you any clues. I am going to try it without using autofit then dvd shrink it if it works. Also I will try to find a non Divx to see if it is only that Codec. Are there some Codecs that dont work well with S2D? I will have to go though my list and remove what I need to. Does the uninstall remove all traces of S2D? If not what left overs must I manualy remove to ensure the entire program is off the system before another reinstall attempt.
-Del
svcd2dvdlog-20090314233817.txt
3 gb avi file containing 1 min of footage, is it normal ?
By codemaster in forum EditingReplies: 2Last Post: 2nd Jan 2012, 11:46 -
Need a set of hi-res custom matrices for 90 - 110 min avi's...(details)
By bxmbxm in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Jan 2010, 18:18 -
cutoff of avi conversions at about 80 min
By jpp2009 in forum ffmpegX general discussionReplies: 0Last Post: 9th Oct 2009, 14:57 -
last few min of avi being cut when converted
By Mr_Del in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 22nd Mar 2009, 02:09 -
All my AVI's seem to come out cropped
By saihossoku in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 01:43
