I am a newbie to the world of VCD and if this is already posted, please forgive me because I could not locate the answer thread.
I have a physical VCD with 2 movies on it and I would like to convert it to 2 DIVX (AVI) files. I want to add the DIVXs to others I have and burn it to a disc. Can anyone help me with a step-by-step or, if you can find a thread with the information on it, direct me to the right path? I did see posts about conversing MPEG-1 to DIVX but I wouldn't even know where to start with the folders and files on a physical VCD.
Thanks in advance![]()
VCD & MPEG Tools should be able to do this for you, IIRC.
Here's the link:
http://www.burningthumb.com/vcdtools.html
Please let us know if this helps. -
Here are a couple of other hints, beyond the useful link that rumplestiltskin kindly offered. A VCD has several folders in it, only one of which has the media file you're interested in. That folder is labeled MPEGAV, and will contain one or more files with a .dat extension. That's where your movie lives. If you see more than one .dat, check the file sizes. Tiny ones tend to be things like adverts, copyright notices, etc. You can ignore the ones you don't want. VLC will play .dat files, so you can check what these are.Originally Posted by DarkPhoenix77
Some conversion software can operate directly on .dat files, but not all can. In those latter cases, use something like VCDgear (free) to convert the .dat files into compliant .mpg files. This does not alter quality in any way -- it just converts file formats, essentially. Because no media conversion is involved, this is very fast.
Once you have plain old .mpg files, you're good to go. Use any of a number of options, including the venerable ffmpegx (not free, but very inexpensive), to convert from mpg to divx.
DivX conversion
By didikai in forum Video ConversionReplies: 2Last Post: 27th Nov 2011, 12:23 -
DivX/Xvid conversion
By joecass in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 16:23 -
DivX 7 Pro mp4 to Divx conversion
By mkochsch in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2010, 03:22 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
...again .mkv to divx conversion...
By Conrad007 in forum Video ConversionReplies: 10Last Post: 6th Jun 2009, 16:37
