So, I've been working on synching up one of my movie rips with a Rifftrax. If you haven't heard of a Rifftrax, enlighten yourself www.rifftrax.com.
Anyways, I managed to extract the AC3 file, convert it to a multitrack WAV with MediaCoder and opened it in Audacity. Then I mixed my Rifftrax with the center channel and exported the whole mess to 6 wav files. Now, I'd like to reencode the whole mess to an MP4 compliant file. To do that, I need to make an AAC file and then mux it with my encoded MP4 video file. But I can't seem to find a suitable tool that will take my 6 WAV files and turn them into a 5.1 AAC file.
Does anyone have any tips for me?
Results 1 to 9 of 9
Megui , eac3to, and behappy will all do it from a single 6-ch wav or ac3, you can download neroaacenc.exe free separately from the nero site
To merge 6 mono wavs, you can use avisynth and feed it into megui or behappy
fl = WavSource("X:\Path\Test_FL.wav")
fr = WavSource("X:\Path\Test_FR.wav")
fc = WavSource("X:\Path\Test_C.wav")
lf = WavSource("X:\Path\Test_LFE.wav")
sl = WavSource("X:\Path\Test_SL.wav")
sr = WavSource("X:\Path\Test_SR.wav")
MergeChannels(fl, fr, fc, lf, sl, sr) -
Buy My Books -
I am converting my DVD's to mkv to be played on my laptop that connects to my TV
I am using HandBrake which have the ability to encode ACC 6 channels discrete. I am wondering if I should do that or just transfert the AC3 audio tracks.
Is it possbile to play AAC 6 channels discrete audio with a PC surround sound system? I know I cant feed it to external home theater systems but if Its playable on a PC I might choose AAC 6 ch for the spaces it saves -
why re-encode the ac3? it's already compressed lossy audio. any more compression is just lost quality and not much saved space if you keep it 5.1.Originally Posted by herbapou
I am keeping the AC3 audio. I have started massive conversion of DVD's to h264/ac3/mkv. Working well and the encode is about of same quality for 1/3 the spaces.
I wanted to save some space has 448 kbps AC3 gives same quality 384 kbps AAC. But you cant send AAC directly to a home theater system so its not worth the trouble.
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 08:41 -
mux h264/aac flv into h264/aac mkv
By Pitorasilo in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2011, 09:36 -
AAC 5.1 to AAC 2ch conversion problem
By MR 3 in forum AudioReplies: 6Last Post: 2nd Feb 2010, 22:44 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:41
