I wonder if anyone can help me with a problem I'm having when capturing TV with my Mercury TV card. I watch the programme as it's recording and the sound coming through the headphones is fine, but when I play back the clip, there is a hiss and a high pitched whine that almost drowns out the sound.
It doesn't happen when I play a DVD on the pc, just on stuff I've captured.
Most capture cards use an audio out from the capture card to an input on the audio card. I'd suspect a faulty connection, a bad cable, or simply bad hardware.
Google is your Friend -
I've checked the connections but never even gave a thought that the cable may be faulty, doh!
I'll try replacing that before I ditch the card. Thanks!
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 15:43 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 02:58
