I am streaming directly from a tvcard and this works well. However, I have set the framerate to 25 fps, but the output is just 6 fps! This means that the image is very shaky, as you'll understand. CPU is at 100%. The funny thing is that a few weeks ago I didn't have this problem, so I know it must be possible to reach a higher framerate.
Whenever I start streaming it begins with about 17 fps, but almost immediately drops to 12 and then to 6 fps. Even the inputscreen is shown shaky.
Any suggestions?
Thanks!
Results 1 to 11 of 11
PLease give us more information.
What software?
What video and audio codec are you streaming in?
What resolution/frame size?
Try change different video codec and resolutions. -
Sorry, Windows Media Encoder.
I have tried almost all different video and audio codec combinations;
340 Kbps and 25 fps.
I really don't understand this. It worked so well! -
Upload is max 1 Mbit/s but on average it is 0,8 MBit/s. Should be sufficient.
I started with higher bitrates, but decreased hoping that would help but it didn't. Smaller frame size doesn't help either.
It seems it needs more CPU? -
Originally Posted by PaulBlok
You can try capturing using a format that is not as cpu intensive (e.g. uncompressed, huffyuv..etc..), then encode offline at a later stage to WMV or your end desired format. Realtime capture/encoding using WMV isn't a good idea because of high cpu usage, thus dropped frames
The bottleneck might become disk I/O depending on what format you choose -
If you have the option, try capturing at quarter D1 (352x288) and stream that. If CPU usage is still to high, resize down to 1/2 (both dimensions) and see if you can stream that.
How to change MKV from 50 fps to 25 fps skipping every second frame?
By andreyyshore in forum EditingReplies: 11Last Post: 5th Feb 2011, 14:09 -
Wrong frame rate (30 fps) for DvdMaestro. Any solutions?
By conax in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2009, 17:36 -
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 04:40 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
