i used to encode my files using canopus encoder ... that seems to give me a good divx encoded avi except for one thing ... my encoded avi's don't seek in my HW player .... i took the video info for both avi's .. befor and after encoding so plz i need help to point out what i'm missing in order to make my files seeks properly in my player , thx
the video info of the orginal file : (that seeks)
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 40mn 20s
Bit rate : 1 063 Kbps
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.197
Stream size : 307 MiB (88%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
the video info of my encoded file : (don't seek)
Video
Format profile : Simple@L1
Format settings, BVOP : No
Codec ID : XVID
Duration : 40mn 20s
Bit rate : 887 Kbps
Width : 640 pixels
Height : 352 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.164
Stream size : 256 MiB (87%)
Writing library : Lavc52.14.0
I'm a bit confused as both files are Xvid, not Divx. Why the Xvid to Xvid re-encode? What are you trying to accomplish?that seems to give me a good divx encoded avi
If you load your AVIs in GSpot, VirtualDub, VLC, etc., do the programs complain about the AVIs' indexes?
Cannot seek DVD on some computer players
By bhilgenkamp in forum Authoring (DVD)Replies: 1Last Post: 27th Apr 2012, 00:44 -
players that play all formats (avi, divx etc)
By ps1on in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th May 2010, 13:14 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 19:55 -
video encoded with divx can't seek with HW player?
By samykoka in forum Video ConversionReplies: 5Last Post: 10th Apr 2008, 16:07 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 23:53
