hello, have data on dvd disc, burned with nero 8, but won`t let me copy from disc to disc, error coming up every time. Also same problem when wanting to make back up of holiday dvds. tried isobuster, imgburn and dvd shrink.Holiday videos were made with sony handycam on mini-dv tapes, captured to pc with ulead to mpg file, then burned with convertxto dvd. any help/advice greatly appreciated.
Yes, first try another computer if you can: if that works, your own burner is probably at fault. If you've had the burner for over a year, and used it a lot, it may simply be starting to wear out or losing compatibility with some media types. Try a completely different disc and see if that works: another brand, 8x instead of 16x, +R instead of -R, R/W instead of R, etc.
If you try another computer, and the copy still fails, then you may have a severe authoring error in those DVDs. This often happens when Nero is involved anywhere in the process- its a very buggy program. It can also happen with good software, sometimes you just get a random repeated glitch with your setup that is unnoticeable because the discs seem to play OK, but when you attempt to back them up later it fails. I have found for some reason that a DVD/HDD recorder will often ignore these authoring/burning errors: if you own one or can borrow one, try loading one of your problem discs and telling the recorder to make a backup copy. When all else fails on my computers, my Pioneer DVD/HDD always makes a backup with no problem.
If these problem discs are not recent, if they're more than a few months old, you have a small possibility that the media was borderline causing a borderline burn that plays but is too error-ridden to pass a computer copy process. There is little you can do in that case, if ImgBurn and IsoBuster don't help. Its always a good idea to alternate two brands of media so you can check them against each other if problems arise later.
Problems with play back packard bell dvd player
By muay in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2010, 12:08 -
How to effectively back up Wii disc?
By coody in forum ComputerReplies: 18Last Post: 3rd Jan 2010, 11:14 -
panasonic bd35 and back up disc
By marky.b in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2009, 10:43 -
How to re-burn these files back to disc?
By Chana1 in forum Authoring (DVD)Replies: 7Last Post: 26th Apr 2008, 00:34 -
dvd play back problems
By cbbs02 in forum Authoring (DVD)Replies: 4Last Post: 13th Jun 2007, 18:43
