I would like to know how can I change the configuration of my video player because if I try to mute the video player then I get also winamp mute. I would like to listen to music and play videos but without sound.
Any idea?
Thanks guys!
Thanks. If I use the mute option then it works, but if I try to lower the volume level then it doesn't.Originally Posted by guns1inger
If I lower the volume in KM, then all the system is mute.Originally Posted by guns1inger
re-configuring virtualdub default compressor codec to another ?
By vhelp in forum Newbie / General discussionsReplies: 9Last Post: 5th Aug 2012, 12:22 -
Need help configuring capture configuration
By tomarwater in forum Capturing and VCRReplies: 4Last Post: 9th Feb 2010, 06:11 -
Configuring microphone w/ Realtek HD Audio
By Sean O'Scare in forum AudioReplies: 0Last Post: 24th Feb 2008, 07:05 -
Easier way of using a gamepad rather than manually configuring every button
By ryangarfield in forum ComputerReplies: 3Last Post: 24th Jun 2007, 09:29 -
configuring tv / dvdcombo/ hd recorder
By nobbydadog in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th May 2007, 10:54
