How does one convert a RAID 5 system to RAID 1 without reinstalling any thing?
one doesn't...you are talking about striped vs. mirrored arrangements.
think of it like this...you can convert those jeans to cut-offs but you can't turn them into silk boxers. -
Thanks for your reply.
Then how does one convert a RAID 5 system to larger harddrives. -
You don't directly.
You copy the data (either to backup HD/CDR/DVDR/BDR/tape--for restore after conversion, or to replacement HD)
If you backup, you could convert: erase...repartition...reformat as newer RAID 5 or 6 or 5+0 or 1+0, etc.
If replacement, you could leave the RAID 5 alone and use new material on it.
Scott -
Your're stuck with the same size disks (partition on the disk), but not the same number of disks, if it's a true RAID cardOriginally Posted by mysts
You can keep adding disks to your RAID, thus adding more storage.
Again this is dependent on your RAID controller. A true RAID controller can do it. but most low end onboard versions don't. Check to see what yours can do.
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 04:13 -
RAID question
By mysts in forum ComputerReplies: 5Last Post: 6th Jul 2009, 15:31 -
1TB Raid?
By CogoSWSDS in forum ComputerReplies: 8Last Post: 30th Sep 2008, 08:35 -
Is Raid 1 always this slow?
By gary11364 in forum ComputerReplies: 7Last Post: 5th Aug 2008, 21:23 -
Using Raid 0 for Rendering?
By jaffacaique in forum EditingReplies: 7Last Post: 3rd Aug 2008, 18:32
