hi all is there any apps that can fix video encoded in h264 like divfix or divfix++ do with avi? i got clip that show wrong time (show clip length 36hr where it is only 1.5hr clip). also it has prb with seek function. many thanks.
Results 1 to 10 of 10
more probably your sample is corrupted
better to reencode the original, or to download a correct file
BHHHDConvertToX, AutoMen, AutoMKV Developer -
well i am thinking to avoid redownload since i am on slower broadband.
Hm, this is odd. I try ffmpeg and now the resulting avi file is fine (shows correct timing and noproblem with seek. However I found that the video and audio is not showing the same time. Video is around 1:12:09 while audio is 1:11:59 (around 10 second differences). What is the best way to combine audio and video again and try to sync it as close as possible, want to avoid mkv if I can.
Edit: I use mkvtool and it seems OK. I will live with it at the moment, thanks for helping me!
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 13:22 -
Possible to fix this FLV/H264/MP4 live stream video?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2011, 15:05 -
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 09:46 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 19:06 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20
