    Dec 2003
    Spain
    Hi,
    I have reinstalled XP in one of my computers. Normally I could play demuxed mpv, mpa and srt with MPC, without muxing them. Now in the fresh XP install the mpa audio is out of sync.
    If I play the same files in other XP computers the audio is synched. I guess something is missing in my new XP but I don't know what. I even installed codecs for mpv and mpa but the audio is still out of sync.
    I would appreciate very much some help.
    Are you using the internal decoders/splitters (mpeg2 and mpeg audio) in MPC on both computers? Check under View->Options->Internal Filters and enable and disable.
    Or try Media Player Classic HomeCinema and see if it works better.
    Dec 2003
    Spain
    Thanks for answering.
    In both computers MPC has the internal filters configured by default.
    I tried the MPC HomeCinema, but id din't work either. It's weird.
