Would I be correct in assuming Flash video is the most common format that plays videos on web sites these days?
How much bandwidth is used playing a typical 1 minute flash video on a web site?
How much does that amount of bandwidth typically cost?
Thanks.
				Results 1 to 11 of 11
	A 1 minute youtube clip is about 2-3MByte. Then you basically just calculate the amount it will be viewed to get the total bandwidth like 1000 views = 2000MB = 2GB. (if they view/cache the entire clip).
 oneminuteclip.flv
	AND if it is "HD" it is much more than that.
 Average movie trailer is usually 1.5min, and those videos are about 25-30MB each, so I'd say ~20MB per minute
 i.e.
 http://www.youtube.com/watch?v=hZnxfyYHJno&fmt=22
 (about 28megs mp4 for less than 2 minutes)
	Yep. But a "typical" web video is not in HD...yet.  . .
	Thank you for your replies.
 So, if a typical 1 minute video is 2MB,
 and my web host charges say $200 per month and provides 2000GB of bandwidth,
 the cost per GB is .10, so the cost of bandwidth for watching a 1 minute 2MB video would
 theorectically = 500 views x 2mb = 1000Mb = 1GB, so 500 views for ten cents? Is that correct?
	also there is no such thing as a "typical" video...what type of video is this? If it's a static frame of a guy standing behind a podium then you need much less than a sporting event..etc.
	Thanks for your reply.
 Can you further educate me on this statement:
 "If it's a static frame of a guy standing behind a podium then you need much less than a sporting event..etc."
 In what way? please explain
	A video with complex movement is harder to compress than is a motionless video, so the example of a sporting event will need a much larger file size than will a talking head (a guy reading the news), for the same quality. However, most video sites, such as YouTube, don't do quality based encodes, but do them for a fixed bitrate, so the ones full of motion just look worse than do the mostly static ones.
	Bandwidth refers to the size of the pipe, not the speed of the data flowing through it. The size of the file does not determine the bandwidth requirements of a streaming video, the bitrate of the video and the number of viewers does. For example if a high motion video takes 4 times the bitrate as a low motion video, then you need 4 times the bandwidth for it to be viewed, which translates to either increasing the bandwidth or reducing the number of viewers. "Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
  Creating a 2 minute videoBy mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 10:26
  Typical lifespan for a stand-alone DVD recorder.By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 22:21
  typical newbie-No video but audio except gomBy nirbhayn in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2008, 15:32
  30 minute video for YouTube, help with encoding please?By sdsumike619 in forum Video ConversionReplies: 2Last Post: 8th Aug 2007, 23:39
  Want to take 0.25 sec video clips from a 10 minute videoBy videocheez in forum EditingReplies: 2Last Post: 2nd Jun 2007, 20:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
