Hi all
I'm thinking of buying a LOGIK LPD860 portable DVD player, because it claims to play MPEG4 files. I took a couple of discs to the shop to check but it failed to play:
H.264/MPEG-4 AVC - avc1 codec (video) with mp4a: MPEG-4 AAC LC (audio) - mp4 container
and
MPEG-4 Video - mp4v codec (video) with mp4a: MPEG-4 AAC LC (audio) - mp4 container
in both cases, frame size is 640x480 and the player errors with "unsupported file format".
Could anyone point me towards what may be wrong? The manual has little technical info and simply states MP4 format - no codec info. Change to a DVD frame size perhaps?
Many thanks
mpeg4 in the context of cheap DVD players usually means Xvid and Divx files encoded within narrow specifications and stored in the AVI container. It rarely means the MP4 container, or H264 video.
Mpeg-4 video compression actually covers some fairly wide ground as far as compression and quality are concerned. Part 4 covers Xvid/Divx et al, while Part 10 covers H264. MP4 - the container - is another kettle of fish altogether.
Refer : http://en.wikipedia.org/wiki/MPEG-4
I suspect the player you are looking at is only able to handle AVI files encoded without qpel or GMC using Xvid or Divx.Read my blog here.
question about how to play video on portable mp4 player
By jimdagys in forum Portable VideoReplies: 15Last Post: 5th Apr 2021, 23:56 -
Issue getting burned dvd-r to play in Sylvania portable dvd player SDVD8727
By deviant_delusion in forum Authoring (DVD)Replies: 2Last Post: 18th Aug 2010, 19:02 -
Portable MP4 player
By vcd_user in forum Portable VideoReplies: 39Last Post: 17th Jun 2008, 08:17 -
Portable DVD Player PHILIPS DCP850 don't play video from iPOD 160GB ?
By BoilerPlate in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Nov 2007, 11:28 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 20:28
