It's like a 4-pin cd audio cable on one side and a 3.5mm jack on the other. I think it's the only way I can record and listen on my PC, using the specific Leadtek TV2000 capture card I have. I don't have a sound card and I don't have AUX or CD IN on my motherboard. I have intergrated sound that I will plug the jack side of the cable in. The other side will plug directly into the capture card.
Thanks!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
you can make one. If you keep old computer stuff around you may have the 4 pin wire just need the jack. If you have a long enough wire with the jack strip the other side and just put plugin pins. Fry's or radio shack have the stuff. I guess they are called componant pins or something .
what about using the 'mic in' on your mobo?
I am just a worthless liar,
I am just an imbecil -
Originally Posted by INFRATOM
You should be able to cut and splice or create a new cable from scratch. There's no limitations. For best connections, you should solder and not just twist and tape. You should also insulate your connections with tape or heat shrink to prevent shorts.
Google is your Friend -
Here's a good procedure you can modify to meet your specific requirements:
http://www.digi-star.com/lit/D3663%20Splice%20Cable.PDF
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 13:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 16:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 14:50 -
HDMI cable seems worse than RBG cable
By BroomQueen in forum DVB / IPTVReplies: 7Last Post: 24th Dec 2007, 17:27
