My brother found some old emulsion-film 8mm movies of home, my wedding 32 years ago, etc. I would like to capture to camcorder, edit with Pinnacle and burn to DVD. I have done a lot of this, converting from analog to digital and editing with my old analog camcorder, but this is my first time capturing film. We also found a device that allows me to project the image on a glass screen, and attach a camcorder on the other end at a right angle and capture the projected movie as the projector plays it.
My camcorder died so I am purchasing a new one.
I am thinking of purchasing this camcorder from Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16830120291
Does anyone see any problems where this will not work? As a side thought, I am open to suggestions for different cameras, but I will not purchase any Sony products whatsoever for their rootkit debacle and other policies.
Does anyone have any general advice for this project? I am not afraid of spending money for this, these videos are priceless and I want to save them before the file deteriorates further.
BTW-I have searched this forum and others and found information, but I really am not up on the latest in camcorder technology; there are hard drives and flash memory now and I thought I would get some comments.
Thanks all...
Nice HDV camera. Obviously, you've done your homework. Make sure your version of Pinnacle will edit HDV. If not, the camcorder will also record standard DV.
Go for it. -
Thanks Filmboss!! I just wanted some input before I put in my order. I really like Canon quality, and while their software that comes with their cameras is a joke, I really don't need it since I use Photoshop anyway. I don't think I will make the videos in HD; these are tapes from the 1960 and 70s of low res and I don't think there would be any improvement, and it might make editing easier. Thanks again...
Hopefully your right-angle projection device has a way to reduce/eliminate the central "hot spot" of light caused by the movie projector's lamp. If not, you're probably not going to be happy with the captured result.
If they're that important, get someone else to do them. Dedicated frame-by-frame film capture machines with the camera focussed on the film gate itself can deliver far better results than you're ever going to get with a standard camera, mirror / screen, and capturing in real time.
There are plenty of threads about this topic, e.g. ...
https://forum.videohelp.com/topic340942.html
If you're going to send your film away, choose the transfer house very carefully!
Hope this helps.
Cheers,
David. -
CSULB71-thanks for the headsup; I am trying to contact my brother (he live in another state) and get some information on this unit he has and will post what info I can. 2Bdecided posted a link with some photos of a home-build mechanism that works on the same principle as the one he has, except his is a commercial model. Thanks to you both.
HD Mini DV camera suggestion?
By alange5 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jul 2011, 13:51 -
Tool suggestion to convert MKV to SWF
By Rafales in forum Video ConversionReplies: 5Last Post: 12th Apr 2011, 11:50 -
Suggestion needed to select my capture device
By syedmahm in forum Capturing and VCRReplies: 18Last Post: 6th Sep 2010, 16:48 -
Need suggestion on how to take clear closeup shot with cheap camera to OCR
By jimdagys in forum ComputerReplies: 4Last Post: 27th Jun 2008, 16:04 -
suggestion for vhs capture card
By abbymat in forum Capturing and VCRReplies: 8Last Post: 28th Jul 2007, 01:57
