is that normal that I cant convert files bigger than like 30 min ...
it says runtime error ..
thank you for the help !!!
Results 1 to 12 of 12
17:03:48 0.98.4 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
17:03:48 Selected Input file: D:\TV Enregistrements\HDPVR\movie.dga
17:03:48 Selected Output dir: D:\TV Enregistrements\Output Xvid\temp\
17:03:48 Selected Final Name: Dieumerci
17:03:48 Selected Container type: AVI
17:03:48 Selected Encoder: XviD
17:03:48 Selected Size: Don't care about size / 1
17:03:48 Selected Profile: 2_Pass_Balanced.xml
17:03:48 Selected Resizer: LanczosResize / 608
17:03:48 Selected Filters: RemoveGrain(mode=2)
17:03:48 Selected Deinterlacer: Progressive
17:03:48 Selected Field Order: AUTO
17:03:48 Specify Bitrate: 950
17:03:48 NeroAACEnc.exe: not present
17:03:48 Enabled Bitrate encoding with value 950
17:03:48 Track Language 1: D:\TV Enregistrements\HDPVR\movie.dga PID 1100 3_2ch 48KHz 384Kbps DELAY -196ms.ac3
17:03:48 Audio Codec 1: Lame
17:03:48 Audio Quality 1: 128
17:03:48 Audio Channel 1: Stereo
17:03:48 Track Language 2: NONE
17:03:48 Audio Codec 2: Lame
17:03:48 Advanced Audio Settings DUMP Track 1
17:03:48 Audio Track Language: und
17:03:48 Nero Option Profiles: AUTO --- Encoding Mode: Quality
17:03:48 CCT Option Profiles: AUTO --- Channel Options: AUTO
17:03:48 Lame Settings: CBR
17:03:48 Audio Normalization: 1
17:03:48 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add:
17:03:48
17:03:53 Extracting audio track 1 D:\TV Enregistrements\HDPVR\movie.dga PID 1100 3_2ch 48KHz 384Kbps DELAY -196ms.ac3 with ffmpeg
17:03:54 Applying DelayCut to audio file: movie.dga PID 1100 3_2ch 48KHz 384Kbps DELAY -196ms.ac3
17:03:57 Encoding D:\TV Enregistrements\Output Xvid\temp\movie.dga PID 1100 3_2ch 48KHz 384Kbps DELAY -196ms.ac3 To Mp3 with 128 Bitrate
17:08:10 DGA File Size: 2679718 bytes
17:09:32 Number of Frames: 98786
17:09:32 Framerate: 29.970030
17:09:32 Movie length in Seconds: 3297
17:09:32 Movie Width/Height: 1920/1080
17:09:33 FIRST pass XviD: "D:\Program Files\AutoMKV\exe\encoder\xvid_encraw.exe" -pass1 -bitrate 950 -turbo -progress -max_bframes 2 -imin 3 -imax 16 -quality 6 -vhqmode 1 -pmax 16 -bmax 16 -bquant_offset 0 -kboost 20 -odegrade 9 -nopacked -nochromame -bvhq -threads 0 -lumimasking -i "D:\TV Enregistrements\Output Xvid\temp\movie.avs" -type 2 -avi "D:\TV Enregistrements\Output Xvid\temp\movie.avi"
17:09:33 SECOND pass XviD: "D:\Program Files\AutoMKV\exe\encoder\xvid_encraw.exe" -pass2 -bitrate 950 -progress -max_bframes 2 -imin 3 -imax 16 -quality 6 -vhqmode 1 -pmax 16 -bmax 16 -bquant_offset 0 -kboost 20 -odegrade 9 -nopacked -nochromame -bvhq -threads 0 -lumimasking -i "D:\TV Enregistrements\Output Xvid\temp\movie.avs" -type 2 -avi "D:\TV Enregistrements\Output Xvid\temp\movie.avi"
18:17:30 Starting Second Pass
18:17:34 Only Movie Size: 494927872 bytes
18:17:34 Using VirtualDubMod for Muxing!
18:17:40 Encoding finished: 00:00:09 elapsed time
18:17:40 -----------------------------------------------------------------------
18:17:40 Script AutoCrop.log
18:17:40
18:17:40 Crop(4,4,1916,1076)
18:17:40 Script movie.avs
18:17:40
18:17:40 #loadpluginstart
18:17:40
18:17:40 #test1
18:17:40
18:17:40 #importstart
18:17:40
18:17:40 #test2
18:17:40
18:17:40 movie = AVCSource("D:\TV Enregistrements\Output Xvid\temp\movie.dga")
18:17:40 function getOrder(clip c) {
18:17:40 order = GetParity(c) ? 1 : 0
18:17:40 Return order }
18:17:40 #filter1start
18:17:40
18:17:40 #test3
18:17:40
18:17:40 last=movie.Crop(4,4,1916,1076)
18:17:40 fixed_aspect = 1.780669
18:17:40 out_width = 608
18:17:40 #Aspect_Error = 0.585%
18:17:40 out_height = 344
18:17:40 #resizestart
18:17:40
18:17:40 #test4
18:17:40
18:17:40 LanczosResize(out_width,out_height)
18:17:40 #filter2start
18:17:40
18:17:40 #test5
18:17:40
18:17:40 RemoveGrain(mode=2)
18:17:40 Script mkvmaudio.avs
18:17:40
18:17:40 LoadPlugin("D:\Program Files\AutoMKV\exe\filter\NicAudio.dll")
18:17:40 LoadPlugin("D:\Program Files\AutoMKV\exe\filter\SoundOut.dll")
18:17:40 LoadPlugin("D:\Program Files\AutoMKV\exe\BeSweet\BassAudio.dll")
18:17:40 NicAC3Source("D:\TV Enregistrements\Output Xvid\temp\movie.dga PID 1100 3_2ch 48KHz 384Kbps DELAY -196ms.ac3")
18:17:40 function addvideo(clip c) {
18:17:40 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100)
18:17:40 Return audiodub(last,c)
18:17:40 }
18:17:40 Normalize()
18:17:40 ConvertAudioTo16bit()
18:17:40 #Applying STEREO downmixing routines
18:17:40 function stereo(clip a)
18:17:40 {
18:17:40 flr = GetChannel(a, 1, 2)
18:17:40 fcc = GetChannel(a, 3)
18:17:40 lfe = GetChannel(a, 4)
18:17:40 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071)
18:17:40 mix = MergeChannels(lfc, lfc)
18:17:40 lrc = MixAudio(flr, mix, 0.2929, 1.0)
18:17:40 blr = GetChannel(a, 5, 6)
18:17:40 Return MixAudio(lrc, blr, 1.0, 0.2929)
18:17:40 }
18:17:40 #
18:17:40 6==Audiochannels() ? stereo() : last
18:17:40 Soundout(output="cmd",type=0,format=0,autoclose=tr ue,executable="D:\Program Files\AutoMKV\exe\besweet\lame.exe",prefilename=" -b 128 --cbr - audio1.mp3",postfilename="",nofilename=true,showou tput=false)
18:17:40 Script mkvmaudio.bat
18:17:40
18:17:40 "D:\Program Files\AutoMKV\exe\matroska\\VirtualDubMod\VirtualD ubMod.exe" "D:\TV Enregistrements\Output Xvid\temp\mkvmaudio.avs" /x
18:17:40 Script VirtualDubMod.vcf
18:17:40
18:17:40 VirtualDub.Open("D:\\TV Enregistrements\\Output Xvid\\temp\\movie.avi",0,0);
18:17:40 VirtualDub.RemoveInputStreams();
18:17:40 VirtualDub.stream[0].SetSource("D:\\TV Enregistrements\\Output Xvid\\temp\\audio1.mp3",0x00000202,1);
18:17:40 VirtualDub.stream[0].DeleteComments(1);
18:17:40 VirtualDub.stream[0].AdjustChapters(1);
18:17:40 VirtualDub.stream[0].SetMode(0);
18:17:40 VirtualDub.stream[0].SetInterleave(1,500,1,0,0);
18:17:40 VirtualDub.stream[0].SetClipMode(1,1);
18:17:40 VirtualDub.stream[0].SetConversion(0,0,0,0,0);
18:17:40 VirtualDub.stream[0].SetVolume();
18:17:40 VirtualDub.stream[0].SetCompression();
18:17:40 VirtualDub.stream[0].EnableFilterGraph(0);
18:17:40 VirtualDub.stream[0].filters.Clear();
18:17:40 VirtualDub.video.DeleteComments(1);
18:17:40 VirtualDub.video.AddComment(0x00000005,"ISFT","Don e with AutoMKV! 0.98.4 http://forum.doom9.org/showthread.php?t=140178");
18:17:40 VirtualDub.video.AdjustChapters(1);
18:17:40 VirtualDub.video.SetDepth(24,24);
18:17:40 VirtualDub.video.SetMode(0);
18:17:40 VirtualDub.video.SetFrameRate(0,1);
18:17:40 VirtualDub.video.SetIVTC(0,0,-1,0);
18:17:40 VirtualDub.video.SetCompression();
18:17:40 VirtualDub.video.filters.Clear();
18:17:40 VirtualDub.SaveAVI("D:\\TV Enregistrements\\Output Xvid\\Dieumerci.avi");
18:17:40 VirtualDub.Close();
18:17:40
18:17:40 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - -
there are no evidence of error in log
where is the crash ?
BHHHDConvertToX, AutoMen, AutoMKV Developer -
about at 67% of first pass .... windows close the program cause of an error .. this is weird .. if its a small video it works good
well my system working good I think lool
Its more the encoder thats crashing!!
that's x264 ,not ffmpeg
please try to update the x264.exe (from the \exe\encoder folder) with latest one from http://x264.nl
it worked now without using ts cutter before so the prob is with ts cutter
so what options do I use so nothing change in my video ... -
just try to make a big avi, then cut avi with virtualdub
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59 -
AutoMKV - am I doing this wrong?
By Phat J in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 02:50 -
AutoMKV no output
By krisman in forum DVD RippingReplies: 16Last Post: 28th Oct 2008, 03:49 -
automkv help...
By Ducco in forum Video ConversionReplies: 0Last Post: 20th Aug 2007, 15:39 -
Trying AutoMKV
By maja_the_bee in forum DVD RippingReplies: 2Last Post: 10th Jun 2007, 06:53
