I am trying to burn a homevideo that I captured with Windows Media Maker.
Dvd Flick says that it is corrupt or trunacted.
I was able to burn it with Favc, but after a few minutes the audio is not in sync.
VirtualDubMod throws cant locate decompressor for format dvsd & avi type-1 dv file detected cannot extract audio from this type of interleaved stream.
What can I do to burn this video correctly. Capture it with a different program or run some tool and correct the video?
Here is the results from MediaInfo.
Format : AVI
Format profile : OpenDML
File size : 10.3 GiB
Duration : 31h 55mn
Overall bit rate : 770 Kbps
Video
Format : Digital Video
Duration : 56mn 29s
Bit rate : 26.0 Mbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 1.500
Original display aspect ratio : 4/3
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Colorimetry : 4:1:1
Scan type : Interlaced
Bits/(Pixel*Frame) : 2.514
Stream size : 10.3 GiB (100%)
Audio #1
Format : PCM
Bit rate : 768 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Resolution : 12 bits
Audio #2
Format : PCM
Duration : 31h 55mn
Interleave, duration : 33 ms (1.00 video frame)
Thanks![]()
what was the source of the video? looks like it might be a miniDV cam, but captured to type I DVavi instead of type II. also the audio is 12 bit not 16 bit but that can be dealt with.
try converting the DVavi to type II with the Canopus DV File Converter and see if that helps.
if it is off of a minidv cam you can capture with windv directly to type II DVavi. it's in the config section.
So frustrated! DVD Rips -> [anything] with Quick Sync = choppy.. sometimes
By s_mack in forum Video ConversionReplies: 39Last Post: 7th Jan 2012, 21:32 -
choppy audio from mpg to DVD conversion - Help
By Warhammerx in forum Video ConversionReplies: 4Last Post: 7th Dec 2008, 19:25 -
Choppy audio and video from ripped dvd
By louthewiz in forum DVD RippingReplies: 1Last Post: 15th Dec 2007, 02:35 -
Making a homevideo more like a theater movie
By qazwsx16 in forum EditingReplies: 12Last Post: 4th Jun 2007, 14:56 -
choppy video/audio in AVI to DVD burning
By spanish in forum Authoring (DVD)Replies: 4Last Post: 15th May 2007, 14:10
