Results 1 to 10 of 10
    Jan 2008
    Netherlands
    I've used to make my DVD menus in 4:3 but now i want to make them in 3:2 widescreen.
    My background image (still) is working ok in simulation mode, but....
    When i build the DVD i get everything in order except for my background still.
    It is build for only 66% and the bottom is missing.
    I can see my overlay with the buttons, but a shitty screen.
    Where is my complete widescreen still?
    I've tried a lot of new photoshop documents in different widescreen variety's but nothing works.
    Anyone overhere who had the same problems?
    Anyone knows how to deal with it?
    I've checked the manual but could'nt find anything.
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    two things:
    1. What template did you use?
    2. did you create the image in Photoshop using the
    following settings?
    I assume your Pal?
    if not use the NTSC settings that match.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Jan 2008
    Netherlands
    Thanks for the reply,
    Yes, i used the PAL settings only you have an older Photoshop program then i use, i think.
    My one gives this:
    But here is an example of how it looks on my screen.
    Any other suggestions?
  4. Member terryj's Avatar
    what template did you use in your project?
    let me know and I'll see if I can duplicate it on my end.
    Yes, I am using Photoshop CS on my end, but Photoshop is Photoshop,
    so that shouldn't be it.
    Urban Mac User
    Jan 2008
    Netherlands
    hello,
    Did'nt use a template....
    Making this menu from ground zero.
    The Dropzone you see in the left is only a short movie playing without start buttons or whatsoever.
    I even went to Ken Stone's website and all the prefs he uses where allready used by me.
  6. Member terryj's Avatar
    Post the link from Ken Stone's website so I can duplicate your results on my end.
    I'd really like to help you solve your issue, however,
    Outside of you doing that for me, I can't offer any further assistance.
    for me to find out where you might have taken a wrong turn I need
    to do what you did and see if I come up with the same result.
    Using my own templates, I do not have the issues you have.
    Creating my own project from scratch, I do not have the issues
    you have. Using PS on my end as above, I have no issues with my
    background menu pictures.
    So I need a clear path to duplicate what you did to see if I can replicate
    first what you did, and from there figure out where you went wrong?
    ok?
    Urban Mac User
    Jan 2008
    Netherlands
    Hello again,
    The website link:
    http://www.kenstone.net
    You find the manuals under Final Cut Pro / Dvd Studio Pro / Setting Up DVD Studio Pro for 16:9 - by Ken Stone NEW
    I followed all his steps.
    By the way, don't i have a problem overhere because i'm using an Intel based machine (Mac Pro 2.8 Dual Quad)?
    Do i have to update from 4.0 to 4.2?
    Is it possible to use a template in 16:9 from DVDSP, delete the dropzones and put in my own background?
    Thanks for all your effort and help.
  8. Member terryj's Avatar
    real quick I have to run out, but:
    The direct link is this correct?
    (always post the direct link, that way if others chime in on this discussion,
    they can quickly be up to speed. It is proper forum ettiquette too )
    I will look at that when I get back and post back my findings.
    Not necessarily for Intel machines, it majorily fixes
    issues with Soundtrack Pro and H.264, among others.
    Still if you want to update in the meantime, it can't hurt.
    *shrugs*
    in theory yes, it is what a lot of us do ( myself included).
    I still think there is something small your missing, so we'll see....
    Urban Mac User
    Jan 2008
    Netherlands
    Yes the link is correct.
    On The Homepage activate "Final Cut Pro".
    Go through the list and activate "DVD Studio Spro".
    Then activate "Setting Up DVD Studio Pro for 16:9 "
    thanx again.....
    P.S. for all you viewers who are having problems with Final Cut Pro and relative programs.
    Go and visit this site, you'll find anything you need.
    Jan 2008
    Netherlands
    I have found the answers to all my problems (i think).
    It seems i need to update to v4.2 for universal binaries.
    As with its brethren, DVD Studio Pro 4.2.1 brings Leopard compatibility. It also includes support for a wide range of new HDV and H.264 formats, as well as fixes for issues with the encoding of still images and writing to multiple DLT tapes.
    Notice what i've found on some Final Cut Pro users group on the net.
    Weird Apple did'nt mentioned it on their site.
    Had saved me a lot of problems.
