Hi,
my problem is when i click on an avi file the explorer crashes. I read about this issue but using the k-lite codec tweak tool to remove broken codecs didn't fix my problem.
So i decided to wipe out my codecs an start from scratch. Now i need your help to do this. I dont know how to uninstall codecs manually (may i just delete the *.ax files?)
I thought i'll leave the windows codecs and cyberlink codecs.
I made a codecs list for you to check it.
klcp_codec_log.txt
Thanks, i did twice repair some filters with filmerit and after rebooting i think my avi-explorer-crash-issue is solved. Woah!!
But i need a bit more testing to verify that it really got solved.
A bit weird, divx50 and xvid movies are still playing though i uninstalled these codecs yesterday.
but after using filmerit there is no preview of divx and xvid avis in the explorer sidebar. maybe that is the reason why i dont have the issue anymore.
EDIT: I realized that i can play divx and xvid without installing their codecs, because VLC uses its on codecs -
The DivX codec is what causes this. There is a fix for it on the DivX website...
http://support.divx.com/anonymous_portal/FAQSearch.aspx?entityId=Q6UJ9A0006FD
Fixing the Explorer crash problem will probably screw up your thumbnail view in Explorer though in which case, you'll need to click Start > Run > regsvr32 shmedia.dll > OK. -
After i used filmerit to solve the problems i used the "Explorer Crash When Open A Folder"-option of the divx-tool. Then i ran regsvr32 shmedia.dll
Now i have thumbnail-preview of images, pdfs and wmv and mpgs. And the explorer doesn't crash anymore. But i dont get xvid coded avi previews. I think this is because i dont have divx codec installed. right?! -
Problem: In Windows 2000 Professional & Windows XP, Windows Explorer will sometimes crash when a large .AVI file is selected.
Cause: By default when certain file types are selected (music and video files) Windows Explorer will load them into a preview utility (which will be visible on the left side of the folder pane [the right pane]). If the file is large/abnormal then it may cause Windows Explorer to crash. This can often happen with large .AVI files.
Work around: The Windows Explorer file preview utility [in the right pane] can be switched off (customised) in 2000 & XP. Any folder which may contain large/abnormal .AVI files should be customized not to use the file preview utility. To do this just right click in a folder/file pane that might contain abnormal/large .AVI files [the right hand pane]. Then left click on ‘Customize this folder…’. Then use a template/view format which does not use the image preview utility. -
I've tried everything in this thread and although the Filmerit did find errors and fixed them, Windows explorer still crashes on AVI files only. Any other suggestions? Is there a way to totally uninstall all Codec files and reinstall them?
Okay, specifically it seems to be the H.264 files that give me the most trouble.Last edited by moviegeek71; 7th Oct 2011 at 21:22.
XMedia Recode Crashes when going to "Filter/Preview" tab
By BoxesofBags in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2012, 13:46 -
Cleaning Up Captured AVI
By Candoo in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2008, 14:29 -
Add JPEG as First Frame - Windows Explorer Preview - Without Reencoding..
By aces27 in forum EditingReplies: 1Last Post: 28th Feb 2008, 10:07 -
Vista Crashes Explorer
By 1magus in forum DVD RippingReplies: 2Last Post: 10th Jul 2007, 15:17
