Here’s my current difficulty:
I have a fully DVD compliant MPEG-2 file all ready to be transformed/processed into a dvd.
My Encore CS3 program broke and I’m still waiting for Adobe Customer support to respond.
Please help me figure out how to finish the dvd authoring process without re-encoding the file utilizing Videohelp.com programs.
Any help or pointers would be greatly appreciated as I’m trying to fulfill a promise made to several people.
Thanks,
Bruce
Results 1 to 14 of 14
According to your other thread, you don't have elementary streams, and there is likely an error in your mpeg2 file
If you have everything ready, and assuming your input files are error free, you can use DVDAuthorGUI, GUIForDVD Author, DVD Styler - all free authoring programs , or if you want more features and control, DVDLab Pro is excellent but costs money -
Another option if you just want to take your mpg2 file and convert it to DVD file structure is to use the DVD Author utility in QuEnc. No menus, chapters, or subtitles, but you don't have to demux to elementary streams first.
Buy My Books -
Gents:
I downloaded and investigated your reccomendations. There are several key elements/considerations here:
a) If I have to demux, it will ruin the audio. Been that route.
a2) No more encoding required.... already in MPEG-2 format
b) My goal is to do exactly what gadgetguy stated!
c) QuENC looks to be a very interesting possibility however it only accepts
.AVS files. How to get an .avs file from an MPEG-2 file? Can it be done?
d) DVD Author GUI requires elementary streams. So that won't work in this particular case. Same thing goes for the DGIndex/Muxman Combo.
e) Is there a well-written, current,striaght forward guide out there that a novice user can execute from for GUIForDVDAuthor or DVD Styler which clearly lays out what to do? Is one better and "easier" that the other?
So, in summary, I would really appreciate your valued input on the following:
1) How to use this MPEG file specifically with the authoring feature on QuENC 0.72. I know nothing about Aviscript.
2) Based upon further details & my particular situation given earlier in this response, to continue to offer commenatry, ideas and suggestions for a solution.
I'd love to hear from all of you and thanks for your kind suggestions and help to date.
Bruce -
If you push the "guides" button, there are several for each and many with screenshots/illustrations (you'll find the button near the rating section when you click on the name of each tool)
Regarding GUIForDVDAuthor and DVD Styler, I doubt they will work for you, because they do internal demultiplexing when they create VOB's, and if you've already failed with 4 or 5 other tools, you will probably have no success with them either. I would concentrate on figuring out how to get a functional DVD compliant MPEG2 video with proper audio out of Premiere first
I don't know about the QuENC author tool , but I have used it as an encoder. I doubt you need an avs script if you are not encoding. -
If demuxing the audio "ruins" it, it was probably already bad to begin with. Demuxing is like unzipper-ing...there shouldn't be anything "wrong" with either the left or right side of a zipper either together or apart.Originally Posted by Canon GL-2 Guy
(Assuming that your audio won't be ruined...)
Any authoring app that accepts compliant pre-encoded files should work. It's just a matter of whether the authoring app requires elementary streams or not (and if it does, you just demux first).
Seriously, if there's a problem, you need to find out what's wrong with the source before proceeding anyway.
Scott -
You misread my recommendation, use the DVD Author tool within Quenc. You access it from the Advanced Options screen.
Buy My Books -
GadgetGuy, (or anyone else that uses this app) Please.... If I may ask in regards to QuEnc 0.72,
1) In order to get the best possible quality, on the advanced options page which lists all sorts of variables, what are the optimal settings for the parameters listed? What do you reccommend?
2) Similiarly, is there anything on the front page when one opens up the app that makes a difference in the end product? It would be very appreciated to either have a screenshot or 2 with the fields filled in with the preferred settings or simply to list them all. Thanks so much. It would be very educational and usefull.
The next time I'll try to remember to render the video to separate audio and video streams on Prem CS3 before archiving all of the data and files!
Thanks,
Bruce -
The DVD Author tool has nothing to do with the encoder, so none of the settings will have any effect. Just click on the DVD Author button, select your source video, set your output directory, then click Author.
Buy My Books -
OK. Gadget guy I'll take your expert word for it.
Thanks for your input.
One whole day has passed and Adobe had not answered by plea for their help to restore Encore CS3.
I highly suspect Adobe support and customer service to some extent resides in Indian or Pakistani call centers because that's the accent the people I talked with had.
Can any of you confirm that?
Anybody have any input on the topic?
Thanks all for you valued particpation.
Bruce
Bruce
How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2?
By kiwisoup in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 23:04 -
By kiwisoup in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 18:53 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 02:05 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 08:13 -
How to Make Authored DVD INTO .ISO WITH TMPGENC DVD AUTHOR
By Chupes in forum User guidesReplies: 4Last Post: 19th Aug 2007, 18:38
