I'm using FAVC to re-encode a PAL 4:3 letterbox DVD to 16:9 (trying to get best possible quality) and the video is fine, but the audio output only shows 2 channels, despite using the AC3 and "Retain if present" audio options.
Any ideas how to keep the 6 channel audio? I've tried both Aften and QuEnc as audio encoders with the same result.
Details below:
Input filmclip.avs (MediaInfo):
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 9s 920ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Sampling rate : 48.0 KHz
Output filmclip.vob (MediaInfo):
Audio
Format : AC-3
Duration : 9s 632ms
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : L R
The process I'm trying is:
1 - rip to HDD with DVD Fab
2 - demux with ProjectX
3 - mux to mpg with ImagoMPEG-Muxer
4 - write AVS script to crop the black bars leaving just the 2.35:1 video
5 - use the AVS script as input to FAVC
Any help appreciated
Sláinte
midders
How are you passing the audio back into FAVC ? I believe that FAVC needs to see a 6 channel AC3 audio track in order to keep it. If you pass through a 6 channel PCM track from Avisynth, FAVC will re-encode it down to 2 channels.
You do realise that FAVC is putting black bars back on the video, because 2.35 is wider than 16:9 ?
Did you know that DVD Rebuilder can do all of this, and preserve the entire disc structure (menus etc) ?Read my blog here.
Thanks; that seems to be the problem. I didn't realise that using AVISynth to crop the video would have an affect on the audio as well.Originally Posted by guns1inger
Yes, just did the cropping to force it to recognize a 2.35:1 sourceOriginally Posted by guns1inger
Yes, I tried this first; I'm trying to see if I can improve on the quality at all.Originally Posted by guns1inger
Thanks for your help
Sláinte
midders -
Generally Avisynth outputs uncompressed video and audio, however mediainfo seems to think the AVS script is outputting AC3, so perhaps the issue is with FAVC after all.
I stopped using FAVC much a while back, as the last release seemed to have issues which have not been addressed. I seem to remember that one of them was a problem with the Retain AC3 if Present function. It might be worth reverting back a version to see if you have better luck.
However if your script is not doing anything more than cropping (i.e. no other filtering is being performed) then it is very unlikely that your results will be any better than DVD Rebuilder's.Read my blog here.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Remove audio with FAVC
By marioval in forum Authoring (DVD)Replies: 2Last Post: 14th Feb 2008, 07:04 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47
