I have used the Hauppauge PVR-150 on my Win XP SP2 computer to convert VHS tapes to mpeg files to use on my Vista MCE computer. The only problem is the converted files have a much higher volume than everything else. I have been looking for a program to allow me to simply lower the volume of these mpeg files but have not been able to find one. I am not a video editor in any way but have used and own some conversion program like from videoredo.
I wondered if anyone could tell me of a simple program that would allow me to lower the volume.
I would demux the mpeg file - load the audio into something like Goldwave or similar....decrease
the volume....output it back to the same audio properties....then remux it back together again.
It's not easy for beginners....but it certainly isn't brain surgery.
You can do it. -
Hauppauge PVR-150 cards are infamous for bad audio quality. In all likelihood its severe damage with volume distortion, not something that can be repaired.
Converted file has lower volume
By pooksahib in forum Video ConversionReplies: 2Last Post: 26th Dec 2010, 03:22 -
Lower volume with Zoom Player
By genegold in forum AudioReplies: 2Last Post: 5th Aug 2009, 00:48 -
Application to lower audio gain of MPEG file?
By headless chicken in forum MacReplies: 6Last Post: 26th Dec 2008, 08:41 -
Sony Vegas 9.0 Platinum how do I raise and lower the volume?
By LoveMyslf in forum EditingReplies: 1Last Post: 7th Nov 2008, 12:28 -
lower file size for a capture
By matneaves in forum Video ConversionReplies: 6Last Post: 1st Sep 2007, 11:34
