I have used Virtual VCR for years with virtually no trouble. It has been with me through system crashes, operating system upgrades, etc. Never had a problem.
Now, all of a sudden in the past two days, I can't capture. I get this error message - "Error 80070003: Cannot start graph." Quick search here, on doom, and via Google showed me this may have something to do with DirectX. So, I downloaded DX 10 and installed. Still, error persists.
I use a Leadtek Winfast TV2000 XP Deluxe capture card. I am running the most recent drivers (which are from 2006). I uninstalled and reinstalled the hardware and the drivers but still no use.
Something happened to all of the sudden cause this error and I can't sort it out. Has anyone had this issue and overcome it? I've made no system changes since the last time I captured a mere week ago so I'm at a loss. I'm running XP so not a Vista issue. I've checked the settings in Virtual VCR and they appear correct. I use huffyUV for compression and the settings are fine. I get a picture and sound in the capture window, the recording just won't start.
Capture card going bad?
Frustrated. Thanks in advance.
You probably need to re-register some of the filter files (like dump.ax). Try uninstalling, then re-installing the program. IIRC, there is a regservice.bat file that you need to run to register some needed filters.
If you haven't used the program in a while and you did any recent OS upgrading/updating, then this is most certainly the problem.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
That did it! Thanks! Re-installed and works fine now. Strange. Thanks for the reply.Originally Posted by SLK001
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
AVISynth Error DirectShowSource: Timeout waiting for graph to start - .m2ts
By onesikgypo in forum Video ConversionReplies: 2Last Post: 22nd Jun 2010, 21:30 -
RipBot error -- DirectShowSource : Timeout waiting for graph to start
By crankharder in forum Blu-ray RippingReplies: 10Last Post: 20th May 2010, 09:19 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
start up programs trouble
By romanstopme in forum ComputerReplies: 8Last Post: 1st Nov 2008, 23:52
